(Redirected from IPad Pro 11)
| IPad Pro 11in 1st Gen | |
| Manufacturer | Apple |
| Code name | A1934/A1980/A2013 |
| Release date | 2018-11-07 |
| Device type | Tablet |
| IPad Not Charging Battery Always Reporting 1 Percent Charge | Motherboard | Soldering | 3. Hard |
| IPad Pro 11 Not turning on, drawing no current with little ticking noise repair | Main Logic Board | Soldering | 3. Hard |
| IPad Pro 11" Fast battery drain (2% per minute) repair | Main Logic Board | Soldering | 3. Hard |
| IPad Pro 11in 1st Gen Not Recognized by PC in Recovery Mode or Charging Issues | Charge port Motherboard | Soldering | 3. Hard |
| IPad Pro 12.9in and 11in No Face ID After Removing The Screen Repair | Face ID | Soldering | 3. Hard |
iPad Pro 1st Gen Mechanic USB-C Readings
