| Sony WH-1000XM4 Headphones Battery Low, Please Recharge Headset Repair | |
| Device | WH-1000XM4, WH-1000XM3 |
| Affects part(s) | Battery |
| Needs equipment | Screwdriver, pry tool |
| Type | Part replacement |
How to fix Sony WH-1000XM4 / WH-1000XM3 headphones that say "battery low, please recharge headset" and will not charge
- Headphones are not charging.
- You hear a low battery message from the headphones.
- If you did not just disconnect/connect the battery, put the headphones on a known good charger for about an hour.
- If you did just disconnect and re-connect the battery, power off the headphones normally then power them back on. The headphones will say this anytime the battery has been disconnected and reconnected or replaced but a reboot always fixes it.
- Use a multimeter to check the battery. Battery should read between 3.7v and 4.2v. If it's outside of this range, replace the battery with another one.
- If the above does not fix the issue and the battery voltage is good, replace the SUB_R board.
