Resistors - Repair Basics
Type Component
Device(s) Resistors
Difficulty ◉◌◌◌ Easy
What is a Resistor?
Resistor symbols commonly found in schematics (Figure 1)
Voltage divider
Voltage divider circuit (Figure 2)
Uses:
  • Reference Voltage: Voltage dividers can be used to create stable reference voltages for sensor calibration, analog signal processing, and feedback in voltage converters.
  • Voltage Monitoring: In some battery-powered devices, voltage dividers are used to monitor the battery voltage to determine its state of charge.
  • And much more
Resistor sensors
Pull-up / Pull-down
Pull-up and pull-down resistors are commonly used in digital electronics to ensure that a digital input signal is in a known state when it's not actively being driven by an external source. They are essential for preventing floating or undefined states
Current measurement
Example and further reading
Fixed value resistors
Different types of resistors (Figure 3)
SMD Fixed value resistors
THT Fixed value resistors
Variable resistors
Potentiometers
Thermistors
Varistors
Photoresistors
Measuring a Resistor (Figure 4)
Testing a Resistor
Wirewound Resistor (Figure 5)
Replacement Considerations
