Poco X3 Pro No Light After 2 SecondS Of Powering ON
Device Poco X3 Pro
Affects part(s) Logic Board
Difficulty ◉◉◉◉ Specialist
Type Soldering, Teardown, BGA
When you turn on the device you will see the "POCO" booting logo for the first 1-2 seconds and after that the screen goes black
  • When the device is booted shows "POCO" logo and after 1-2 seconds screen goes blank
Light on
  • Graphics are still hardly visible (with external source of light)
No Light, only graphics
  • Light section turns off
  • Phone boots up normally
  • High Diode value on the Display_CABC, the diode value on this should be ~ 0.610v
CABC DISPLAY
If you have all the symptoms mentioned above then proceed to the repair steps.
This problem occurs due to a missing CABC(pwm) line, this controls the brightness supplied to the display panel. Usually this track gets damaged from inside so the best way to repair it is to make a jumper from under the power ic to the display connector.
  • Make sure the Diode Value on this pin is High or OL
  • Remove the Power IC
PMIC
  • Take a jumper from under the pmic (exact pad shown in the picture) and make a jumper to the display connector (exact pad shown in the picture)
CABC UNDER PMIC
CABC DISPLAY
  • Reinstall the power ic and test.
