PlayStation 5 Not turning on repair
Device PlayStation 5
Affects part(s) Motherboard
Diagnosing and fixing issues related to "No power" on a PS5
  • Not turning on
  • Check power supply is outputting 12v at PSU Connector on board
  • Check for shorts around rear of southbridge IC CXD90061GG. This may indicate the IC itself is to blame. Replacements are available and they're not married.
  • Plug your bench power supply into the 12v input pins. If you have no 300ma boot sequence, remove BIOS IC for 10-20 minutes completely from the board, re-solder and retry. If still no change reprogram BIOS with a working digital edition copy of the BIOS (this will remove the ability to use a BDROM on disc editions)
  • Video (Credit: TheCod3r)
