PlayStation 5 Fault Finding Using UART
Device PlayStation 5, PlayStation 5 Slim, PlayStation 5 Pro
Affects part(s) Motherboard
Needs equipment Soldering Iron, USB-TTL Device
Difficulty ◉◉◌◌ Medium
Type
Introduction
Example of a USB-TTL Device
Required tools
PS5 UART Connections
PS5 Read Error Logs Example Output
What to do with the Codes?
UartCodes.com [2]
