MacBook Pro A2289 Touchbar brightly flashes following shut down or login repair
Device MacBook Pro A2289
Affects part(s) BridgeOS/T2
Needs equipment
Difficulty ◉◉◌◌ Medium
Type Part replacement, Software
When the touchbar flashes after shutdown or login, this will be related to corrupted BridgeOS firmware and will be resolved via a DFU revive or restore.
  • Flashing touchbar
DFU Revive or restore BridgeOS
If the issue still is not resolved after touchbar replacement, the issue is likely related to the T2 chip's internal GPU and cannot be repaired without replacing the system board, or replacing the T2 chip. (Not recommended.)
