MacBook Pro A2159 No camera detected repair
Device MacBook Pro A2159
Affects part(s) Motherboard
Addressing issues with MacBook Pro 820-01598 not detecting the camera.
  • Camera not detected
  • Possible burned or exploded L8504 filter on TCON board
Check L8504 Continuity
  • Use a multimeter in continuity mode to check L8504 (Figure 1).
  • Normal reading should be close to 0.01.
  • If L8504 is blown or burned, proceed to the "L8504 blown or visibly burned repair steps" below.
Test with Known Good Display
  • Verify camera function using a KNOWN GOOD display assembly.
  • If the camera works with a different display, the original display might be faulty.
  • Make sure to check L8504 before diagnosing the display issue.
If camera works with a known good test display, replace the display assembly.
L8504 Blown or Visibly Burned
  • Understand that L8504 failure indicates a catastrophic short within the TCON board of the display or a melted/corroded display cable/connector.
  • Repair L8504 only after addressing the display issue, as L8504 might fail again if the display issue persists.
  • When replacing L8504, address corresponding pad and trace damage.
  • Use 36 or 37 AWG enamel coated copper wire for jumper wires due to webcam and ambient light sensor power requirements.
  • Connect jumper wire from the input side of the filter (PP5v_G3S) C5250.
  • Apply conformal coating to jumper wire.
  • Use a 120 Ohm ferrite filter rated for 1.5 amps (402 package size).
  • After replacing L8504 and addressing trace issues, replace the display assembly or repair it by replacing damaged cables/connectors.
No Camera Function, L8504 Normal
  • Attempt to restore T2/BridgeOs firmware via Apple Configurator 2 by entering DFU mode.
  • Ensure your Mac is on the latest macOS version.
  • Follow Apple's support article on reviving or restoring T2/BridgeOs firmware.
  • If no camera function after firmware revive, and other causes are ruled out, U8504 might be faulty, or there could be trace/resistor issues between the camera connector/U8504 or between U8504 and the T2 chip.
  • A hardware issue with the T2 chip might also cause camera detection problems.
If it is not any of the above, then it might be a failed camera secure disable chip (U8502). This is very rare.
