MacBook Pro A1990 Restarting repair
Device MacBook Pro A1990
Affects part(s) TouchBar, Main Logic Board
Needs equipment Screwdrivers
Type Parts Disassembly"Parts Disassembly" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property.
Problem Description
MacBook Pro 15” A1990 randomly restarts shortly after boot. Before restarting, you may notice the trackpad freezing for a few seconds, and then macOS triggers a kernel panic.
A panic log shows BridgeOS panic, which drives the Touch Bar.
This issue is commonly caused by a faulty Touch Bar or BridgeOS communication failure, not by macOS, SSD, or user data.
MacBook Pro A1990 Touch Bar (bridgeOS) Panic Log
  • Mac boots to macOS, but freezes shortly after startup.
  • Trackpad stops responding before reboot.
  • Device restarts on a loop.
  • Touch Bar not working (blank or unresponsive).
  • No liquid damage or visible board damage.
  • Apple Diagnostics and Disk Utility show no errors.
  • Issue persists in Safe Mode and Recovery Mode.
MacBook Pro A1990 Touch Bar FPC Connector Location
  1. Check Panic Log
    • Panic log will mention bridgeOS issues.
    • This confirms Touch Bar communication error.
  2. Visual Inspection
    • Inspect Touch Bar flex cable and connectors for corrosion or physical damage.
    • Check for pin damage at Touch Bar connector on logic board.
  3. Test Without Touch Bar
    • Disconnect the Touch Bar flex from the logic board.
    • Boot macOS and observe behavior.
    • If restart loop stops, Touch Bar is confirmed faulty.
Solutions
Option 1: Disconnect Touch Bar (Temporary Fix)
  • Disconnect Touch Bar flex from logic board and run Mac without Touch Bar.
  • If system boots and stays stable, you’ve isolated the issue.
  • Note: Device will run without Touch Bar functionality.
Option 2: Replace Touch Bar Assembly
  • Replace Touch Bar or entire Top Case with a known-good part.
  • This resolves BridgeOS crash and restores full functionality.
