| MacBook Pro A1708 Not turning on, pulling 0.35A at 20V repair | |
#incomplete
- Not turning on
- Pulling 350 milliamps at 20V as measured by a USB-C meter
PP5V_S5 missing — check and reflow or replace U7650 (TPS51980) with proper pads cleaning (especially on the PPBUS_G3H_P3V3S5 input of U7650). Possible problem: Apple refurbished board; solder over corrosion causing bad joint. Example of replacing a corroded TPS51980
Dead CPU or bad BIOS can also present like this.
