| MacBook Air A1932 No display backlight repair | |
| Device | MacBook Air A1932 |
Identifying and solving backlight issues on the 820-01521 logic board, as well as similar boards from 2016-2020. A MacBook with no backlight on the display is experiencing an issue where the screen remains dark even though the computer is powered on and operational. This means that while the computer itself may be functioning, the display is not emitting any light, making it extremely difficult or impossible to see the content on the screen. Shining a strong light on the display at an angle might reveal that the content is indeed present, but the backlight is not illuminating it.
Check for a short to ground on backlight output PPVOUT_LCDBKLT_F
- C8469 or adjacent capacitors in the series is an appropriate area to measure, since it does not require removal of the system board.
Check U8400 and its circuit
Failure of U8400 without the presence of liquid damage is uncommon, however if you have no backlight with a known good display, and do not have a short on backlight output, U8400 may be bad or you may have another circuit fault such as a bad resistor or broken trace within the U8400/backlight generation circuit.
It is also common for current sensing pins (pins 9 and 10) of U8400 to be very corroded with corresponding pad/trace damage. If this is the case, run a wire for each pad and connect them to U5620 (Which is a omitted/no-stuff component.) Pin 9 (ISNS_LCDBKLT_N) can be run to Pin 5 of U5620 and Pin 10 (ISNS_LCDBKLT_P) can be run to pin 4 of U5620.
- You should have ~3.3v. Low voltage (less than 3.3v but more than 0v) on pin 2 of R8442 (Figure 4) is suggestive of an issue with U8400.
- Check the 5v inputs to U8400 PP5v_S0_BKLT_D
- If PP5v_S0_LCDBKLT_D is low (Substantially lower than 5v), replace U8400 AND R8444 as R8444 acts as a current limiting resistor to protect PP5v_G3S, and likely blew as a result of an internal short within U8400.
- If you have low voltage on pin 2 of R8442 with normal voltage on pin 1 of R8842, replace U8400.
- If VIN, EN, and PP5v_S0_LCDBKLT_D are all present at normal levels, and you do not have backlight, replace U8400.
- To retain keyboard backlight function, be sure to use the same year display.
