| LG Ultrafine 5k 27MD5KA-B Display completely unresponsive test mode fails repair | |
| Device | LG Ultrafine 5k 27MD5KA-B |
| Affects part(s) | PSU |
| Needs equipment | |
| Type | Part replacement |
Display is 100% unresponsive, test mode doesn't work.
- Display is 100% unresponsive.
- Test mode doesn't work (see Test mode.)
Suspected faulty power supply.
Disassemble monitor and unscrew power supply, making sure to be careful with components such as capacitors which can hold charge for a substantial amount of time after being unplugged, make sure to touch the board holding only the edges.
- Check the two fuses for continuity, replace if needed.
- Check capacitors for swollen tops.
- Check for any charred or miscolored components.
The power supply board is possible to buy online if needed.
https://www.ebay.com/p/7031234791
