IPhone XR not powering on with heat above the CPU
Device IPhone XR
Affects part(s) Motherboard
Needs equipment
iPhone XR will not power on. Before prompt to boot there is heat above the CPU
  • You get 1A or higher current draw before prompt to boot on DC Power Supply
  • You feel heat above the CPU
  • You either have a cracked Speaker Amp (U5002)
  • Or a shorted cap on PP_SPKAMP_TOP_VBOOST
  • Use a Thermal Cam or Freeze Spray to pin point the root cause of the short
  • If Speaker Amp is cracked, replace it
  • If you have a shorted cap remove it and then check PP_SPKAMP_TOP_VBOOST with multimeter in diode mode to verify short is no longer present. You don't need to replace shorted cap if short is no longer present
Migrated from old wiki
