IPhone 15 Pro Max Dead and Not Charging
Device iPhone 15 Pro, iPhone 15 Pro Max
Needs equipment Soldering Iron, Multimeter, Thermal Camera, Rosin, Hot Air Station, Microscope
Difficulty ◉◉◉◉ Specialist
iPhone 15 Pro Max appears dead and will not turn on or charge when on battery. When connected to a DC Power Supply (DCPS), the device consumes 0.105-0.130 A of current before prompt to boot and boots normally after prompt. Thermal imaging shows the charging IC heating abnormally.
Figure 1 - iPhone 15 Pro Max DCPS reading before prompt to boot example
  • Device appears dead, no response to power button or charger.
  • No charging indication on screen.
  • Device only boots when connected to DCPS.
  • DCPS reading: 0.105-0.130 A before prompt to boot.
  • Charging IC visibly heats up on a thermal camera.
  1. Connect iPhone to DC Power Supply; check current draw:
    • 0.105-0.130 A pre-boot draw indicates boot sequence initiates.
  2. Attempt to prompt the phone to boot using power button.
  3. Observe thermal camera or use Rosin to detect heat source:
    • Charging IC heating confirms failure.
Figure 2 - Example of charging IC heating up under thermal camera
  1. Disassemble Device:
    • Remove display and disconnect battery.
  2. Board-Level Work:
    • Remove motherboard from housing.
    • Split Layers
    • Isolate charging IC area (use thermal shielding).
  3. Remove Faulty Charging IC:
    • Use hot air + flux, carefully lift the IC.
  4. Clean and Prepare Pads:
    • Wick old solder and inspect for pad damage.
  5. Install New Charging IC:
    • Reball, align, and install.
  6. Test Booting and Charging:
    • Connect to DCPS, verify normal reading before prompt to boot.
    • Check battery charging functionality.
  7. Reassemble Device:
    • Confirm full functionality before sealing.
      Figure 3 - iPhone 15 Pro / Pro Max Charging IC (International Variant)
      Figure 4 - iPhone 15 Pro/Max Charging IC (USA Variant)
