How To Program ROM Chip for iPads with CD3217
Device
Affects part(s) Logic Board
Difficulty ◉◉◉◉ Specialist
Some iPads using the CD3217 USB-C controller IC can develop a no charge, no boot, or low voltage negotiation issue. This typically happens after liquid damage or a power surge. Replacing the CD3217 alone doesn’t fix the issue, because the connected ROM IC is often corrupted or burned.
⚠️ Important: The CD3217 and ROM chip are not paired, but the ROM stores crucial firmware/data required for CD3217 functionality. If the CD3217 fails, it often damages the ROM, and a new CD3217 will not function unless the ROM is replaced or programmed.
  • Symptom 1 (Figure 1)
    • USB-C power meter shows only 5V — no voltage negotiation (should be 15–20V)
  • Symptom 2
    • New CD3217 IC installed but still no charge
  • Replace both CD3217 and ROM IC
  • Program a new ROM using JC V1S Pro (or dump from donor board)
  • Install both chips
  • Charging will be restored
  1. Visual Inspection
    • Look for signs of corrosion around the CD3217 and ROM area (usually near USB-C port)
    • Check for burnt ROM chips or CD3217
  2. Voltage Testing
    • Use USB-C power meter or bench power supply
    • Plug in USB-C and check if iPad negotiates proper voltage
    • 5V = error (bad CD3217/ROM or negotiation issue)
Step 1: Remove Damaged CD3217 & ROM
  • Desolder both the faulty CD3217 and the adjacent ROM IC
  • Clean area properly, ensure all pads are intact and usable
Step 2: Prepare New CD3217 + New ROM IC
  • Use a fresh CD3217 IC from a trusted supplier
  • Get a blank ACE SPI Flash chip — compatible size for your board
  • Program the ROM using :
    • JC V1S Pro with ACE SPI ROM Adapter
Step 3: Program the ROM Chip
Option A: JC V1S Pro Server
  • Use JC V1S Pro with their SPI ROM adapter
  • Select your iPad model and download the correct ROM dump from their server
  • Program the ROM with one click
Option B: Donor Board ROM Dump
  • Pull a working ROM chip from a donor board of the same model
  • Use JC V1S Pro to read and save the dump
  • Flash the dump onto your blank ROM IC
  • Store dumps in a labeled folder (example: iPad Pro 11 2nd Gen CD3217 ROM.bin)
Step 4: Reball & Install CD3217
  • Reball and solder new CD3217 in place
  • Ensure all surrounding passives are intact
  • Use thermal camera to confirm no hotspots or improper current draw
Step 5: Install Programmed ROM
  • Solder the newly programmed ROM chip in original location
  • Clean with IPA and inspect joints under microscope
