Nintendo 3DS
Revision as of 20:48, 30 June 2025 by Tiago199988 (talk | contribs) (Added device pictures)
Nintendo 3DS
Manufacturer Nintendo
Code name CTR
Release date 2011-02-26
Device type Game Console
Nintendo 3DS blue light turns on then turns offScreen flex cable
Motherboard
Part replacement
Cleaning
Software
General
Teardown
About/Info
Power-up sequence
From power loss
  • Voltage regulation kicks in, the MCU gets powered
  • The MCU boots up
    • I2C lines are initialized
    • Configuration resistors are scanned
    • Power regulation is configured
      • Battery presence detection is configured (independent of pins BAT+, BAT-, or the middle pin being shorted anywhere)
      • Charger presence is detected
    • Battery rejection is run
The system is ready for the handling of the Power button press, even if the configuration is invalid (shorted battery lines, lack of sufficient battery charge, battery is rejected, etc.).
Soft start
  • Do state vericiation of the hardware
      • If the battery is rejected, do emergency shutdown
    • If this is a kiosk unit, and charger *presence* is not detected, cancel the power sequence
  • Change the Power LED animation to the fade-in pattern
  • Configure voltage regulation for the SoC
  • Take SoC out of reset (/RESET1 and /RESET2 are no longer active)
  • The PLL eventually locks, and the ARM9 bootrom starts executing, shortly followed by the ARM11 bootrom
    • Cryptographic things are initialized
    • Boot devices are discovered
    • First valid boot option is booted, or if none are valid, the infamous blue screen is displayed
