Samsung Galaxy A53 5G Network issue
Device
Affects part(s)
Needs equipment
Difficulty
Type
In this condition, your phone experiences severe network issues. You may notice one or more of the following:
  • No network service.
  • Only emergency calls are possible.
  • Complete inability to make or receive calls.
  • The phone continuously switches between "Emergency Calls Only" and "No Service."
  • Sometimes signal bars appear, but they are only for emergency calls.
  • Occasionally, a blocked or crossed-out icon replaces the signal bars.
  • Flight Mode can be toggled normally (the button is not greyed out or stuck).
  • You can manually switch between different network modes (2G, 3G, 4G, 5G), but the problem remains.
Root Cause
The issue is usually caused by a malfunctioning or shorted APT IC located near the CPU. When the APT IC fails or operates inconsistently, it disrupts the network power supply (VPA_APT), leading to unstable or no network service.
There are 2 ways to fix this issue:
  1. Replace the ic.
  2. Bypass the ic but not by removing it
front network section
  1. Check for Shorts:
    • Inspect the area around the network-related ICs for short circuits (see the image)
  2. Measure VPA_APT Output:
VPA_APT COIL
  • Probe the VPA_APT coil output (in the picture)
  • The expected voltage should be in the range of 2.0V to 4.2V (depending on battery voltage)
  • If the reading is 0.00V or fluctuates continuously, proceed to repair steps
Solution 1: Replace the APT IC
VPA_APT IC
  • Remove the shield covering the IC.
  • Desolder and remove the faulty APT IC(shown in the picture)
  • Inspect the PCB pads for any damage.
    • If pads are intact, proceed.
  • Reball the replacement APT IC using 183°C (medium-temp solder paste).
  • Install and solder the new IC onto the board.
  • Verify the repair by checking network functionality.
Solution 2: Bypass the APT IC (Jumper Method)
VPA_APT to VPH_PWR JUMPER
  • Locate the VPH_PWR point on the motherboard (shown in the picture)
  • If the APT IC is burnt, first remove the VPA_APT boost coil.
  • Create a jumper wire connecting VPH_PWR to the VPA_APT output (refer to image for exact points).
  • Apply solder mask to secure the jumper and prevent shorts.
  • Test the phone’s network functionality.
