How To Fix an iPhone 15 That Randomly Restarts
Revision as of 18:01, 10 June 2025 by VCCBoardRepairs (talk | contribs) (test)
Device iPhone 15, iPhone 15 Plus
Difficulty ◉◌◌◌ Easy
Type Part replacement
There are many reasons that could cause an iPhone 15 and iPhone 15 Plus to randomly restart every few minutes. For the iPhone 15 series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
The most common for iPhone 15 series are:
  • Back Glass/Wireless Charging Flex- This is the flex that is attached to the Back Glass. It can damaged during a drop or screen replacement
  • Proximity Flex -This is the flex that is attached to the screen. It can easily be liquid damaged or torn during a screen replacement.
If you see:
  • 0x200000 - it's the Wireless Charging Flex (Back Glass)
    • Could be a sandwich issue
  • 0x80000 - it's the Charging Port Flex
  • 0x100000 - it's the Proximity Flex Cable
  • 0x280000 - it's the Wireless Chargin Flex + Charging Port Flex
    • Make sure both flexes are plugged in
  • Bad or damaged flex
