EliteBook 850 G5 Windows HP Hotkey Support
Device EliteBook 850 G5
Affects part(s) Windows OS
Needs equipment None
Difficulty ◉◌◌◌ Easy
Type Software
Hewlett-Packard automatically pushes a firmware update through the Windows updater that opens blank windows when some function keys are pressed.
HP Hotkey Error Window
  • After pressing the brightness or volume keys, a small blank window appears titled "HP Hotkey Support".
Install the correct driver with the link below and disable the bad driver.
Press brightness/volume keys in Windows and see if blank window appears.
Windows 10
  1. Download https://ftp.hp.com/pub/softpaq/sp91501-92000/sp91903.exe and install the correct driver.
  2. Press the windows key + R. Type services.msc and press enter.
  3. Scroll down to "HP Hotkey" and adjust the settings for the two services below by right clicking > start/stop and properties menu.
    1. "HP Hotkey Service" should be running, automatic startup. This is the correct driver.
    2. "HP Hotkey UWP Service" should be stopped and disabled. This is the defective driver.
  4. The bad firmware will automatically update occasionally and you will need to disable the bad driver again.
