| PlayStation 5 Fault Finding Using UART | |
| Device | PlayStation 5, PlayStation 5 Slim |
| Needs equipment | Soldering Iron, USB-TTL Device |
| Difficulty | ◉◉◌◌ Medium |
| Type | |
Introduction
Required tools
What to do with the Codes?
UartCodes.com [2]
