PlayStation 5 Fault Finding Using UART
Revision as of 22:30, 27 May 2025 by Tiago199988 (talk | contribs)
Device PlayStation 5, Playstation 5 Slim
Affects part(s) Motherboard
Needs equipment Soldering Iron, USB-TTL Device
Difficulty ◉◉◌◌ Medium
Type
Introduction
Example of a USB-TTL Device
Required tools
PS5 UART Connections
PS5 Read Error Logs Example Output
What to do with the Codes?
UartCodes.com [2]
