PlayStation 5 Fault Finding Using UART
Revision as of 14:12, 23 May 2025 by Tiago199988 (talk | contribs)
Device Playstation 5
Affects part(s)
Needs equipment
Difficulty ◉◉◌◌ Medium
Type Troubleshooting/Diagnostics"Troubleshooting/Diagnostics" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property.
Introduction
Example of a USB-TTL Device
Required tools
PS5 UART Connections
PS5 Read Error Logs Example Output
What to do with the Codes?
UartCodes.com [2]
