CD3217 compatibility
Revision as of 15:27, 19 May 2025 by TLamy (talk | contribs)
Type
Device(s) MacBook Air A2137
MacBook Pro A2141 MacBook Air A2337 MacBook Pro A2338 MacBook Pro A2442Property "Device" (as page type) with input value "MacBook Air A2137</br>MacBook Pro A2141</br>MacBook Air A2337</br>MacBook Pro A2338</br>MacBook Pro A2442" contains invalid characters or is incomplete and therefore can cause unexpected results during a query or annotation process.
Difficulty
"Medium" is not in the list (1. Easy, 2. Medium, 3. Hard, 4. Specialist) of allowed values for the "Repair Guide difficulty" property.
[[Category:Explanatory guides for MacBook Air A2137 MacBook Pro A2141 MacBook Air A2337 MacBook Pro A2338 MacBook Pro A2442]]
About the CD3217
The CD3217 Power Delivery (charge port) controllers are used in a wide range of MacBooks and other Apple devices. It is made by Texas Instruments (based on the TPS65986) exclusively for Apple, and thus can not be purchased from an official distributor.
Since it can be not acquired through official channels, it has to be sourced from donor boards. Given it has internal firmware that differs by model and/or operational mode and that can't be modified, your best bet is to use same board same place donors. See the table below for compatible donor boards.
There is exactly one CD3217 per charge port. One operates in Master mode (usually connected to the dfu capable port), the other one(s) in Slave mode. A defective CD3217 is one of the two probable causes for a MacBook to not request 20V from the charger (the other one being a short somewhere).
Operational Details
A couple of people have reverse engineered parts of the inner workings of the CD3215 and CD3217 on https://blog.rickmark.me/ace-controller-secrets/. This information is not essential to repair a device using these chips, but a good background story to understand if a specific device behaviour may be related to the CD3217.
Compatibilty chart
A2141 A2159 A2179 A2251 A2289 A2337 A2338 M1 A2338 M2 A2442 A2485 A2779 A2780
A2141 X X
A2159 X X
A2179 X
A2251 X
A2289 X
A2337 M/S M/S M/S
A2338 M1 M/S M/S M/S
A2338 M2 M/S M/S M/S
A2442 M/S
A2485 M/S
A2779 M/S
A2780 M/S
