IPhone XR not powering on with heat above the CPU
Revision as of 18:31, 14 May 2025 by Samhext (talk | contribs)
Device IPhone XR
Affects part(s) Motherboard
Needs equipment
iPhone XR will not power on. Before prompt to boot there is heat above the CPU
  • You get 1A or higher current draw before prompt to boot on DC Power Supply
  • You feel heat above the CPU
  • You either have a cracked Speaker Amp (U5002)
  • Or a shorted cap on PP_SPKAMP_TOP_VBOOST
  • Use a Thermal Cam or Freeze Spray to pin point the root cause of the short
  • If Speaker Amp is cracked, replace it
  • If you have a shorted cap remove it and then check PP_SPKAMP_TOP_VBOOST with multimeter in diode mode to verify short is no longer present. You don't need to replace shorted cap if short is no longer present
Migrated from old wiki
