IPhone XR freezes at the last digit of the pin code
Revision as of 18:23, 14 May 2025 by Samhext (talk | contribs)
Device IPhone XR
Affects part(s) Motherboard
Needs equipment
iPhone XR will boot up normally but freeze and restart when pincode is entered
  • Phone boots fine
  • Type in your pin code & at the last digit, it freezes, keeping that digit highlighted for about 30-60 seconds
  • Then the screen restarts and you're back at the pin code screen.
  • Check NFC (U_NFC_S) above CPU
  • It most likely has a hairline crack & requires to be replaced.
  • Once replaced, the phone will go through a "swipe to recover" screen in most cases, where you put in the pin code, it loads a white "Attempting Data Recovery" screen & takes about 10-20 minutes.
  • This is basically the operating system rewriting the NFC chip, so it can unlock.
  • Then, the phone will work fine afterwards
Migrated from old wiki
