| IPad Pro 12.9 5th Gen | |
| Manufacturer | Apple |
| Code name | A2378, A2379, A2461, A2462 |
| Release date | 2021-05-21 |
| Device type | Tablet |
| Cant Draw Diagonal Lines After Screen Replacement | Display | ||
| How To Program ROM Chip for iPads with CD3217 | Logic Board | Soldering | 4. Specialist |
| IPad Not Charging Battery Always Reporting 1 Percent Charge | Motherboard | Soldering | 3. Hard |
| IPad Pro 12.9 5th Gen Touch Screen Not Working | Motherboard | Soldering | 3. Hard |
| IPad Pro 12.9 5th Gen not powering on due to long screw damage | Motherboard | Soldering | 3. Hard |
| IPad Pro 12.9in and 11in No Face ID After Removing The Screen Repair | Face ID | Soldering | 3. Hard |
iPad Pro 12.9 Gen 5 - Known Good Mechanic USB C Readings
IPad Pro 12.9 5th gen board overview
IPad Pro 12.9 5th Gen LCD diode mode readings - 1
IPad Pro 12.9 5th Gen LCD diode mode readings - 2
IPad Pro 12.9 5th Gen LCD diode mode readings - 3
IPad Pro 12.9 5th Gen LCD diode mode readings - 4
IPad Pro 12.9 5th Gen charging port diode readings - 5
