How to Troubleshoot And Fix iPhone Random Restarts Using Panic Logs
Revision as of 19:46, 4 November 2023 by ASRepairs (talk | contribs) (Created page with "{{Explanatory Guide}} Here is a master list of all the known paired parts, that will give you a "Unknown Part" message when you replace it. Most of them will still function fine but a notification will pop up after you first turn on the phone after it detects it doesn't have the original part. One thing to note, you will get these messages, even if you replace them with genuine parts from another OEM iPhone. The new genuine parts are required to be "calibrated" by Ap...")
Type
Device(s)
Difficulty
The new genuine parts are required to be "calibrated" by Apple, to avoid getting the message about the part being non-genuine.
Model Battery Display Rear Cameras Rear System TrueDepth Camera
iPhone SE 2020, iPhone SE 2022 X
iPhone XS, XS MAX, XR X
iPhone 11, 11 Pro, 11 Pro Max X X
iPhone 12, 12 Pro, 12 Pro Max, 12 Mini X X X
iPhone 13, 13 Pro, 13 Pro Max, 13 Mini X X X X X
iPhone 14, 14 Plus, 14 Pro, 14 Pro Max X X X X X
iPhone 15, 15 Plus, 15 Pro, 15 Pro Max X X X X X
Some examples of the messages you'll get when these parts are replaced by "Non-Genuine Parts"
File:Important Battery Message.png
Important Battery Message - What you'll see when you replace a battery with a "non-genuine" part.
File:Important Display Message.png
Important Display Message - What you'll see when you replace a screen with a "non-genuine" part.
File:Important Camera Message.png
Important Camera Message - What you'll see wen you replace the rear cameras with "non-genuine" parts.
Source: https://support.apple.com/en-us/HT212878
