The PlayStation 3 (commonly referred to as PS3) is a home video game console developed by Sony Computer Entertainment. The console was developed to be a successor to the PlayStation 2. The PlayStation 3 was designed to compete against Microsoft's Xbox 360 & Nintendo's Wii with both consoles being part of the "7th generation of video game consoles".
| Playstation 3 | |
| Manufacturer | Sony Computer Entertainment |
| Code name | |
| Release date | JA: November 11, 2006
NA: November 17, 2006 EU: March 23, 2007 AU: March 23, 2007 |
Models
The PlayStation 3 has had 29 model variations over its lifetime, with all of the models going through minor revisions throughout its life.
The table below gives a brief overview of every retail PS3 that has ever released. Keep in mind the two digit suffix indicates what that model was made for e.g. CECH-3003B.
PlayStation 3 Fat Model list [1]
| Model # | PS2 Compatibility? | Original HDD Size | CELL | RSX | Notes |
CECH‑Axx
Yes: EE, GS, & RDRAM hardware included. | 60gb | 90nm | 90nm | Launch NTSC model. Not released in PAL regions |
CECH‑Bxx
Yes: EE, GS, & RDRAM hardware included. | 20gb | 90nm | 90nm | Launch NTSC model. Not released in PAL regions. |
CECH‑Cxx
Yes: GS hardware included. EE & RDRAM emulated via software. | 60gb | 90nm | 90nm | Launch PAL model. |
CECH‑Exx
Yes: GS hardware included. EE & RDRAM emulated via software. | 80gb | 90nm | 90nm | NTSC version of the CECH-Cxx model. The only other difference is HDD size. |
CECH‑Gxx
No | 40gb | 65nm | 90nm | Last model to use NAND flash memory to store firmware. |
CECH‑Hxx
No | 40gb | 65nm | 90nm | First model to use NOR flash memory to store firmware. |
CECH‑Jxx
No | 40gb | 65nm | 65nm | First model to use a 65nm RSX (CXD2982GB or CXD2982BGB), potentially less vulnerable to failure (which causes YLOD). Note that a new revision of the 65nm RSX (CXD2991GB) was introduced only 2 months later, which could potentially indicate some sort of issue with the first revision was caught early on and a new "hotfix" revision pushed out to fix it. |
CECH‑Kxx
No | 80gb | 65nm | 65nm | |
CECH‑Lxx
No | 80gb | 65nm | 65nm | Notably different motherboard layout, also introduces a new revision of the 65nm RSX (CXD2991GB), potentially further reducing risk of failure. It is notable that this variant of the RSX was introduced only 2 months after the first 65nm RSX, which could point to this being a "hotfix" revision of sorts, though it could also just be because of the new mobo layout. |
CECH‑Mxx
CECH‑Pxx
No | 160gb | 65nm | 65nm | |
CECH‑Qxx
No | 160gb | 65nm | 65nm | Last model of the fat PS3 lineup. |
PlayStation 3 Slim Model list [1]
| Model # | PS2 Compatibility? | Original HDD Size | Possible Board Revisions | CELL | RSX | Notes |
CECH-20xxA
No | 120gb | DYN-001 | 45nm | 65nm | |
CECH-20xxB
No | 250gb | DYN-001 | 45nm | 65nm | |
CECH-21xxA
No | 120gb | SUR-001 | 45nm | 40nm | |
CECH-21xxB
No | 80gb | SUR-001 | 45nm | 40nm | |
CECH-25xxA
No | 120gb or 160gb | JTP-001, JSD-001 | 45nm | 40nm | |
CECH-25xxB
No | 250gb or 320gb | JTP-001, JSD-001 | 45nm | 40nm | |
CECH-30xxA
No | 160gb | KTE-001 | 45nm | 40nm | |
CECH-30xxB
No | 320gb | KTE-001 | 45nm | 40nm |
PlayStation 3 Super Slim Model list [1]
CECH-40xxA
No | 16gb eMMC | MPX-001, MSX-001, NPX-001 | 45nm | 40nm or 28nm | |
CECH-40xxB
No | 250gb or 500gb | MPX-001, MSX-001, NPX-001 | 45nm | 40nm or 28nm | |
CECH-40xxC
CECH-42xxA
No | 16gb eMMC | MPX-001, MSX-001, NPX-001, PPX-001, PQX-001 | 45nm | 40nm or 28nm | |
CECH-42xxB
No | 250gb or 500gb | MPX-001, MSX-001, NPX-001, PPX-001, PQX-001 | 45nm | 40nm or 28nm | |
CECH-42xxC
CECH-43xxA
No | 16gb eMMC | RTX-001, REX-001 | 45nm | 28nm | |
CECH-43xxB
No | 250gb or 500gb | RTX-001, REX-001 | 45nm | 28nm | |
CECH-43xxC
Note: The NPX-001, PPX-001, PQX-001, RTX-001 and REX-001 motherboard revisions all feature a 28nm die shrunk RSX packaged on a smaller substrate layer, which uses half the number of RAM chips of the previous 40nm design. In addition, the CELL's substrate layer was reduced in size on the PPX-001, PQX-001, RTX-001 and REX-001 revisions; however, the die size appears to have remained unchanged at 45nm. See: PS3 Super Slim Die Comparison
Region / Suffix list [2]
| Region | Suffix | Example |
| Japan | 00 | CECH-A00 or CECH-2000A
| USA / Canada | 01/15 | CECH-A01 or CECH-2001A
| Oceania | 02 | CECH-A02 or CECH-2002A
| United Kingdom / Ireland | 03 | CECH-A03 or CECH-2003A
| Europe / Middle East / Africa | 04/16 | CECH-A04 or CECH-2004A
| Korea | 05 | CECH-A05 or CECH-2005A
| Southeast Asia | 06 | CECH-A06 or CECH-2006A
| Taiwan | 07 | CECH-A07 or CECH-2007A
| Russia / Ukraine / India | 08 | CECH-A08 or CECH-2008A
| Latin America | 11/14 | CECH-A11 or CECH-2011A
| Hong Kong | 12 | CECH-A12 or CECH-2012A
General Issues
| Problem | Solution |
| Applications won't launch, can't update the console |
| PS3 freezes on boot, laggy XMB, games/apps freeze, longer than usual load times |
| Loud fan or Overheating |
| RLOD (Red Light of Death) |
| YLOD (Yellow Light of Death)/Visual artifacts (Bad color after a few minutes and/or lines on screen) | This could be caused by a multitude of problems:
It is highly recommended to get the exact error codes from the syscon before proceeding with any specific repair. Note that bad solder balls and bad bumps generally give the same types of errors, but failed bumps can only be fixed by replacing the RSX. If replacing the RSX, it's recommended to consider replacement with a newer 40nm RSX that is not prone to the same issues that the 90nm and some 65nm versions of the RSX are prone to. This is similar to what Sony did for a small number of officially refurbished consoles. More information here |
Diagnosing the YLOD (Yellow Light of Death)
All fat PS3s can suffer from the Yellow Light of Death. Unfortunately, a YLOD doesn't really tell much, other than a failure in the hardware initialization phase has occurred. This can mean anything from a dead GPU to a dead capacitor supplying power to the southbridge. To really know for a fact where in the hardware_init phase it failed, you'll need to solder a UART connection to the system controller (a.k.a syscon). For now, follow the documents included in this repository or this guide (Windows)
Deep dive video on YLOD failures
If the syscon gives primarily power failure codes, replace the NEC/Tokin caps. These do not remove easy, even with a hot air station. They most likely will come out in pieces. Many guides show using tantalum caps at an angle. My experience is using 330uF caps from MacBook boards 820-2850 is a good option. These caps have a second ground closer to the positive terminal. This allows you to solder the 4 per NEC/Tokin without being at an angle or without exposing more of the ground plain. Also important to note, if replacing all 4 NEC/Tokins on this particular model, a jumper will be needed from 1 end of positive to the other, as the NEC/Tokins have an internal bridge.
If 0E128 NEC/Tokin use 470uF, 4 per NEC/Tokin
If 0E108 NEC/Tokin use 330uF, 4 per NEC/Tokin
