Transistors - Repair Basics | |
Type | Component |
Device(s) | Transistors |
Difficulty | ◉◌◌◌ Easy |
What is a Transistor?
Amplification
Switching
Voltage Regulation
Motor Control
BJTs come in two types:
NPN
PNP
FETs are classified into JFETs (Junction Field-Effect Transistors) and MOSFETs (Metal-Oxide-Semiconductor Field-Effect Transistors) and they both have two types:
N-Channel
P-Channel
Testing a Transistor
BJTs
FETs
IGBTs
- Place the red probe on the emitter (E) and black probe on collector (C), you should measure a diode voltage drop (typically 0.6 - 0.7 V).
Replacement Considerations
BJTs
FETs
IGBT
