Transistors - Repair Basics | |
Type | Component |
Device(s) | Transistors |
Difficulty | ◉◌◌◌ Easy |
What is a Transistor?
Amplification
Switching
Voltage Regulation
Motor Control
BJTs come in two types:
NPN
PNP
FETs are classified into JFETs (Junction Field-Effect Transistors) and MOSFETs (Metal-Oxide-Semiconductor Field-Effect Transistors) and they both have two types:
N-Channel
P-Channel
FETs can have two gates in some applications.
IGBTs combine the characteristics of BJTs and MOSFETs. They are used in high-voltage, high-current switching applications like inverter drives and power inverters.
Testing a Transistor
Testing a transistor can help determine if it is functioning correctly. You can use a digital multimeter to test transistors for both amplification and switching capabilities.
- Identify the transistor's pins and determine its configuration (NPN or PNP for BJTs, or N-channel or P-channel for FETs). 3. Test the transistor's collector (C), base (B), and emitter (E) pins for BJTs or gate (G), source (S), and drain (D) pins for FETs.
BJTs
FETs
IGBTs
- Usually, IGBTs come with a diode connected in reverse parallel "freewheeling diode" to allow current to pass in the other direction. This means that all you have to do to measure an IGBT is check if the diode is still functional.
- Place the red probe on the emitter (E) and black probe on collector (C), you should measure a diode voltage drop (typically 0.6 - 0.7 V).
Replacement Considerations
BJTs
FETs
IGBT
