Diodes - Repair Basics | |
Type | Component |
Device(s) | Diodes |
Difficulty | ◉◌◌◌ Easy |
What is a Diode?
One way path
The most basic function of a diode is to serve as a unidirectional pathway for the flow of electrical current.
Rectification
Voltage Regulation
Zener diodes, a specific type of diode, are used to regulate voltage. They maintain a constant voltage across their terminals despite changes on the supply voltage, making them suitable for reference voltage used in power supplies and protecting sensitive components from voltage spikes.
Protection
Photodetection
Regular/Rectifier Diodes
Schottky Diodes
Zener Diodes
Zener diodes are designed to maintain a constant voltage across their terminals when operated in the reverse-biased breakdown region. They are used for voltage regulation and are often labeled with their nominal voltage value.
Light Emitting Diodes (LEDs)
Varactor Diodes
Varactor diodes, also known as varicap diodes, are used in tuning and frequency modulation applications due to their ability to change capacitance with a varying reverse bias voltage.
Photo-diodes
Testing a Diode
Identifying a Zener diode's zener voltage
- Using a Lab-Bench Power Supply, connect the positive terminal to the cathode of the diode and the negative terminal to the other end of the resistor.
Replacement Considerations
