Speed up Legacy Computers with Special Linux Distros
Revision as of 20:08, 13 April 2025 by Harald3DCV (talk | contribs) (Improve formatting.)
Type Laptops"Laptops" is not in the list (Component, Circuit, Troubleshooting/Diagnostics, Method, Idea/Concept) of allowed values for the "Explanatory Guide Type" property.
Device(s)
Difficulty ◉◌◌◌ Easy
Do you have an old computer that's been collecting dust since you upgraded to a newer model? Don't throw it away just yet! With the help of Linux, you can breathe new life into your old computer and make it run faster than ever before. In this guide, we'll show you how to get started with Linux and recommend some of the best distributions to use for legacy hardware.
Why Use Linux on Old Computers?
Let's try to escape the buy-new-soon-to-be-outdated-stuff mentality businesses are encouraging. Linux is awesome for this purpose because:
  • Highly customizable: Linux allows you to optimize your system for low-end hardware, making it a great choice for older machines that may struggle with modern operating systems.
  • Hundreds of distributions: There are hundreds of Linux distributions available, and many are designed specifically for older hardware.
  • Security and stability: Linux is renowned for its security and stability, which is important when running older hardware that may be more susceptible to crashes and other issues.
  • Environmentally friendly: Reviving an old computer with Linux is an environmentally friendly choice that reduces e-waste and helps extend the lifespan of existing technology.
Common Concerns about Linux
Many people are hesitant to switch to Linux because they believe it requires expert knowledge. However, this is a common misconception. There are many user-friendly Linux distributions that are designed specifically for users with little or no experience with Linux.
For example, Zorin OS is a Linux distribution that is targeted specifically for users who have previously used Windows. It has a Windows-like interface and comes with many pre-installed applications that are commonly used on Windows.
Chrome OS Flex is another Linux distribution that is extremely user-friendly. It is designed to run on Chromebooks and other devices, and its interface is very similar to that of Android. It is designed to be easy to use, even for those who have no experience with Linux.
Finally, if your device is mainly used for surfing the web, the operating system doesn't matter that much in the end. As long as your browser of choice is available on Linux, you should have no trouble browsing the web.
Getting Started with Linux
Before you can start using Linux on your old computer, you'll need to download and install a Linux distribution. Here's how to get started:
  1. Prepare a USB drive with at least 4 GB of storage. This will be used to install the Linux distribution onto your computer.
  2. Download Rufus (for Windows) or Etcher for creating a bootable USB drive.
  3. Choose a Linux distribution that's suitable for your hardware (see below for recommendations).
  4. Flash your USB drive with the downloaded Linux distribution image using Rufus or Etcher.
  5. (Optional) Most Linux distributions allow you to try them out via booting directly from the USB drive. You can test the distribution this way before installing it on your computer.
  6. Backup important data of the target system. It's also recommended to backup data for dual boot installations, in case something goes wrong unexpectedly.
  7. Install the new operating system (see the linked installation guide for the distribution you choose).
Recommended Linux Distributions
There are many Linux distributions to choose from, but not all of them are suitable for old or low-spec hardware. Here are some of our top recommendations:
Distribution Advantages Hardware Requirements Download Installation Guide
Zorin OS Core Modern design,
Windows 10-like user interface,
easy dual boot support
CPU: 1 GHz Dual Core – Intel/AMD 64-bit processor
RAM: 2 GB
Storage: 10 GB
ChromeOS Flex Modern design,
very user-friendly (like Android),
very robust (but no native app support)
BUT it's not Free and Open Source Software (FOSS), so Google could ditch support anytime.
RAM: 4 G
Storage: 16 GB
Hardware Components made before 2010 might result in a poor experience
Linux Lite Very low hardware requirements CPU: 1 GHz Dual Core
RAM: 768 MB
Storage: 8 GB
Puppy Linux Ultra-low hardware requirements 32-bit version:CPU: Single-core Pentium 4 or equivalent
RAM: 512 MB
64-bit version:
CPU: Dual-core
RAM: 1 GB
Download Installation GuideAlso check out LICK.
Lubuntu Popular (official) Ubuntu flavor,
with lower hardware requirements.
Unofficial Requirements:CPU: 1 GHz
RAM: 1 GB
Storage: 5 GB
More info here.
Note: Distros like Tiny Core Linux have even lower requirements, but they might not be as suitable to a broad user base.
Common issues
  • tbd
