| IPad Air 4 | |
| Manufacturer | Apple |
| Code name | A2316, A2324, A2325, A2072 |
| Release date | 2020-10-23 |
| Device type | Tablet |
| How To Fix an iPad Air 4 boot looping after water damage using Panic Logs | Ambient Light Sensor | 2. Medium | |
| How To Program ROM Chip for iPads with CD3217 | Logic Board | Soldering | 4. Specialist |
| How to reprogram the CD32 ROM with Wylie SPI Programmer | motherboard | 4. Specialist | |
| IPad Air 4 No Backlight | Backlight circuit | Soldering Part replacement | 3. Hard |
| IPad Air 4 Not Reading Touch | Motherboard | Soldering | 3. Hard |
| IPad Air 4 Stuck on recovery mode | Motherboard | Soldering | 3. Hard |
| IPad Not Charging Battery Always Reporting 1 Percent Charge | Motherboard | Soldering | 3. Hard |
iPad Air 4 - Charging Port Diode Mode Readings
iPad Air 4 A2316 - Mechanic Reader Values
iPad Air 4
Model Numbers:
- A2316 Wi-Fi Only
- A2324 Wi-Fi + Cellular
- A2325 Wi-Fi + Cellular
- A2072 Wi-Fi + Cellular
