| Diodes - Repair Basics | |
| Type | Component |
| Device(s) | Diodes |
What is a Diode?
Diodes are typically identified by the symbol shown in Figure 1 and are usually denoted with the letter D followed by an identifier number. (E.g., D38)
Rectification
Voltage Regulation
Zener diodes, a specific type of diode, are used to regulate voltage. They maintain a constant voltage across their terminals, making them suitable for stabilizing power supplies and protecting sensitive components from voltage spikes.
Switching
Diodes are used as switches in various applications, including signal routing, switching power supplies, and protection against reverse voltage.
Rectifier Diodes
Rectifier diodes are the most common type of diodes used for converting AC to DC. They come in various package types and sizes.
Zener Diodes
Zener diodes are designed to maintain a constant voltage across their terminals when operated in the reverse-biased breakdown region. They are used for voltage regulation and are often labeled with their nominal voltage value.
Schottky Diodes
Light Emitting Diodes (LEDs)
Varactor Diodes
Varactor diodes, also known as varicap diodes, are used in tuning and frequency modulation applications due to their ability to change capacitance with a varying reverse bias voltage.
Photodiodes
Testing a Diode
If the diode is in a circuit, you can test it in-circuit, but keep in mind that other components in the circuit may affect the reading.
Replacement Considerations
When replacing a diode, always read the datasheets and consider the following factors:
- Power Rating: Match the power rating of the replacement diode with the original diode.
