MacBook Pro A1707 No backlight repair
Revision as of 15:59, 29 October 2023 by ASRepairs (talk | contribs)
Device MacBook Pro A1707
Identifying and solving backlight issues on the A1707 MacBook, as well as similar boards from 2016-2020. A MacBook Pro with no backlight on the display is experiencing an issue where the screen remains dark even though the computer is powered on and operational. This means that while the computer itself may be functioning, the display is not emitting any light, making it extremely difficult or impossible to see the content on the screen. Shining a strong light on the display at an angle might reveal that the content is indeed present, but the backlight is not illuminating it.
  • Verify that the screen assembly does not have the "flexgate" issue. Open laptop just a tiny bit and see if image/backlight shows. You can tell it is a flexgate issue when you can see a backlight when the machine is barely open, but you cannot see a backlight once the screen is fully open. This is caused by the screen cable being too short and is a design fault that Apple released a service program for, but only for 13" 2016 models. The exact same cable and therefore the exact same problem also occurs on 15" models but there is no service program for it. To fix the flexgate issue, replace the screen cable with the longer version that is sold as a spare part. You can watch a video of how to fix the flexgate issue here....
  • Short to ground on backlight output due to bad capacitor on output.
Example video (0 V on backlight circuit, 59 Ω short to ground caused by bad capacitor)
  • Bad screen—if backlight voltage is 49–55 V, bad screen. This can also be caused by the flexgate issue. Watch the video linked above for more info on how to fix the flexgate issue.
  • Corrosion on current sense vias/traces for backlight to U8400, pins 9 and 10. Example video (skip past TPS51980 replacement): Example video
