| MacBook Pro A2251 no Backlight on display repair | |
| Device | MacBook Pro A2251 |
Identifying and solving backlight issues on the 820-01949 logic board, as well as similar boards from 2016-2020. A MacBook Pro with no backlight on the display is experiencing an issue where the screen remains dark even though the computer is powered on and operational. This means that while the computer itself may be functioning, the display is not emitting any light, making it extremely difficult or impossible to see the content on the screen. Shining a strong light on the display at an angle might reveal that the content is indeed present, but the backlight is not illuminating it.
This issue can be caused by multiple factors, you need to determine which one is present in your situation.
Check for Backlight Output Short
- Measure for a short to ground on backlight output (PPVOUT_LCDBKLT_F).
- Use C8471 (Figure 1) or adjacent capacitors for measurement; unplug the display connector to rule out issues with the TCON board or LED strip.
- Proceed to "Backlight output shorted to ground" repair steps if a short is present.
Check U8400 and its circuit
Identify and replace the shorted component. Check with and without the display connected. A short is commonly caused by a shorted capacitor. Inject 10v at 5 amps, thermally image the board, or use comparable short detection methods.
Replace the display assembly.
Corroded U8400
If U8400 is corroded or adjacent components are corroded, replace them.
Check pins 9 and 10; if corroded, connect them to R8400; Pin 9 to Pin 4, Pin 10 to Pin 3 (Figure 4).
Backlight Fuse (F8400) Blown in Absence of Short to Ground
Replace the backlight fuse with a compatible replacement (0603 package, 3 amp, 32v fuse).
