MacBook Pro A2159 Not turning on, fluctuating current draw 0.03-0.1A at 20V repair
Revision as of 15:28, 29 October 2023 by ASRepairs (talk | contribs)
Device MacBook Pro A2159
Affects part(s) Motherboard
This issue is often caused by a short to ground on a sub-rail, which can be accurately detected with a high resolution thermal imaging scan. Low resolution thermal imaging may not reveal the subtle signs of a small shorted component, making it a less reliable diagnostic method.
  • No power
  • No fan spin
  • All voltages missing
  • Perform High Resolution, High Sensitivity thermal imaging of the entire system board.
    • Low resolution thermal imagers will likely not pick up the subtle temperature changes failures like this often present with.
    • The failure will often present as a component quickly heating up and cooling down in sync with the amperage changes; Occasionally, you will find a resistor heating up/cooling down in sync with the amperage changes.
    • The short is likely caused by something on the output side of the resistor.
  • Remove and Replace the shorted component based on thermal imaging findings.
