APC Back-UPS ES 350VA
Revision as of 00:34, 17 October 2024 by The Cre8r (talk | contribs) (update language)
Manufacturer APC
Code name
Release date
Device type Other
40 AMP FUSE REPLACEMENT
The board has a 40-amp blade-style fuse that may go bad. If the device has a known good battery and the device is having the symptoms of "Replace Battery" per the user guide. To replace the fuse:
  • Remove the battery and battery cover
  • Remove the 4 Phillips screws
  • Remove the back cover
  • Disconnect all connectors on the main board and remove the main board.
  • Test continuity on the 40-amp fuse.
  • Desolder and resolder a new 40-amp blade-style fuse.
  • Place the main board back and reconnect all connectors.
  • Return battery wires through labeled openings on the back cover and reinstall.
  • Screw in 4 screws.
  • Install battery and cover.
  • Complete.
Internal Fuse - 40 Amp Blade Style
Battery - RBC35Please consider contributing pictures to this section!
Product Page: https://www.apc.com/us/en/product/BE350G/apc-backups-es-350va-120v/
User Guide: https://download.schneider-electric.com/files?p_enDocType=User+guide&p_File_Name=EALN-7CEQDH_R1_EN.pdf&p_Doc_Ref=SPD_EALN-7CEQDH_EN
