JuiceBox
Revision as of 21:48, 9 October 2024 by ChrisC (talk | contribs) (tweak)
(up to EV chargers section)
NOTE: This page was created in early October, in the wake of the Enel X shutdown, to start to capture JuiceBox information. If you spot some incorrect or missing information below, FIX IT YOURSELF! This is a wiki, meaning it's editable by anyone -- create an account and edit in the correction. See the main "EV chargers" page above for more information about this site.
JuiceBox hardware models:
  • original JuiceBox, funded via Kickstarter campaign in 2013; "Base" model was simple metal box; "Premium" model base was designed to look like a huge AA battery; both were available as rewards to campaign backers in either assembled form or kit form (cheaper)
  • JuiceBox Classic 40 (basic 40 Amp EVSE, no connectivity / app), released 2013
  • JuiceBox Pro 40 (advanced 40 Amp EVSE with connectivity / app), released 2013
  • JuiceBox Pro 40 (no model name difference?), overhauled under Enel X, released in 2017
  • also 32 Amp, 48A and 75A versions of the above
  • JuiceBox Pro 40 Lite (same but stripped of some features)
  • JuiceBox 2.00 hardware
  • JuiceBox 2.01 hardware
  • smartphone app Enel X Way (Apple/Android), required to make configuration changes to the stations (via Enel X cloud), for example changing the current / amperage setting
  • smartphone app JuiceNet, predecessor to above that was produced by EMW, deprecated in March 2024
  • JuiceRouter, a LTE-to-Wifi gateway used to connect up to 16 stations to the cloud
Immediate actions for JuiceBox owners to take before Oct 11th, that can only be done via app:
  • Note that this might be as early as 12:01am Oct 11th CEST (European time), since Enel is headquartered in Italy; in the USA that would be 3:01pm PT / 6:01pm ET.
  • Consider disabling the Smart Charging setting. If it is enabled, your JuiceBox will only charge cars during a preset time window. Once the app is discontinued, we do not know if this setting will become permanent. Note: most EVs have TOU / time window capability built in, and can be set the car's UI or in the car's app (or both). via Kishore Devisetti on LinkedIn
  • Make any desired changes to max charge amps. Double check that your station is set to match your breaker; for example, a station on a 40 Amp breaker should be set to deliver no more than 32 Amps (due to the 80% rule for continuous loads). It could be set wrong and still wroked, but only because you had an EV that could only draw a lower current. New EV could lead to blown circuit. Just sdobule check it while you still can.
  • Consider disabling any charge energy limits.
  • After making last change, edit OCPP server setting to null?
e.g. LED blink patterns
Common failure modes
How to disassemble
how to update firmware
software tools required
description of port location
description of software steps
  • link
  • link
  • link
  • link
