JuiceBox
Revision as of 03:55, 7 October 2024 by ChrisC (talk | contribs) (added JuiceRescue and juicepassproxy)
(up to EV chargers section)
The JuiceBox series of EVSE hardware was first developed by eMotorWerks (EMW), an independent EV shop founded by Val Miftakhov, and they brought the first generation JuiceBox to market in 2013. In 2017 the company was purchased by the Italian utility company Enel, operating under the subsidiary EnerNOC, which was later rebranded as Enel X and Enel X Way.
  • original JuiceBox, funded via Kickstarter campaign in 2013; "Base" model was simple metal box; "Premium" model base was designed to look like a huge AA battery; both were available as rewards to campaign backers in either assembled form or kit form (cheaper)
  • JuiceBox Classic 40 (basic 40 Amp EVSE, no connectivity / app), released 2013
  • JuiceBox Pro 40 (advance 40 Amp EVSE with connectivity / app), released 2013
  • JuiceBox Pro 40 (40 amps delivered), overhauled under Enel X, released in 2017
  • also 32 Amp, 48A and 75A versions of the above)
  • JuiceBox Pro 40 Lite (same but stripped of some features)
  • JuiceBox 2.00 hardware
  • JuiceBox 2.01 hardware
  • smartphone app Enel X Way (Apple/Android), required to make configuration changes to the stations (via Enel X cloud), for example changing the current / amperage setting
  • smartphone app JuiceNet, predecessor to above that was produced by EMW, deprecated in March 2024
  • JuiceRouter, a LTE-to-Wifi gateway used to connect up to 16 stations to the cloud
e.g. LED blink patterns
Common failure modes
How to disassemble
how to update firmware
software tools required
description of port location
description of software steps
  • link
  • link
  • link
  • link
