MacBook Pro A1990 Battery not recognized repair
Revision as of 15:25, 29 October 2023 by ASRepairs (talk | contribs)
Device MacBook Pro A1990
Affects part(s) Motherboard, battery
MacBook A1990 not recognizing the connected battery
  • MacBook not turning on.
  • Battery not recognized/charging
  • First, try a known good battery.
    • If it doesn't work, check the battery cable going to the board.
      • Sometimes there is corrosion here, sometimes the customer tore the bar on the connector off the connector.
  • In some rare cases the SMC still is a factor in battery recognition on this board.
