There are many reasons that could cause an iPhone 15 Pro and iPhone 15 Pro Max to randomly restart every few minutes.
For the iPhone 15 Pro series, there are some sensors within the parts of the phone that are required to be plugged in & detected. Otherwise, the phone restarts on its own.
Charging Port Flex - This is the flex towards the bottom of the phone. It is easily damaged with a drop & the back glass is breaks. Or when someone has repaired the back glass.
Back Glass/Wireless Charging Flex - This is the flex that wraps around the logic board & controls the power button.iPhone 15 Pro Max - Wireless flex diagram. If it's unplugged, it will restart giving panic log error 0x400000
Bad Battery - If the battery is defective or goes bad, it can cause restarting problems.
After a back glass repair, the iPhone will restart on its own every few minutes
After a hard drop, the iPhone will restart every 3 minutes.
After a screen repair, the iPhone will bootloop every 3 minutes
After replacing the charging port flex, the device will auto restart on its own randomly.
The iPhone will reboot randomly when using it.
The iPhone will seem to freeze and restart every 2-5 minutes.
If you see:
0x200000 - It's the Proximity Flex
Only affects the 15 Pro and not the 15 Pro Max
Make sure this flex is plugged in
Check that no flex is torn, liquid damaged, defective
Test with OEM or Premium. Aftermarket Flexes have a high defect rate
Diode mode the FPC connectors for any fault
0x300000 - It's the Charging Port FlexiPhone 15 Pro Max Panic log example. It will restart if the charging port flex is unplugged, causing 0x300000 panic log error
iPhone 15 Pro Max will restart if the charging port flex is unplugged, causing 0x300000 panic log errorMake sure this flex is plugged in
0x400000 - It's the Wireless Charging Flex on the Back Glass
Diode mode the FPC connectors for any faultPanic Log Example of 0x400000, which is due to the wireless charging flex being unplugged
0x600000 - It's 2 problems, the Proximity Flex and Wireless Charging Flex
Make sure both flex cables are plugged in
0x700000 - It's 2 problems: Charging Port Flex and Wireless Charging Flex
0xa1 - It's a battery data issue.
Sometimes you'll see the battery percentage fluctuate or you'll randomly get a "non-genuine" message.
Check the battery connector pins. Sometimes they can bend out & battery won't make good contact.
Diode mode the battery connector pins & compare them to known good board
Test with a known good battery
Replace the battery connector
iPhone 15 Pro Max - Device will restart every 3 minutes if the battery is bad, giving error 0xa1
Bad or damaged flex
Low quality aftermarket flex
Other flex cables that are Liquid Damaged
Please note: You MUST have the required flex cables, (Charging port flex, Wireless Charging Flex, etc) plugged in. Otherwise, it WILL restart. You cannot troubleshoot this step by unplugging the bad flex.
