MacBook Pro A1708 Not turning on, pulling 0.02A at 5V repair
Revision as of 10:16, 27 October 2023 by ASRepairs (talk | contribs) (Created page with "{{stub}} {{Repair Guide |Device= |Affects parts= |Needs equipment= |Type= |Difficulty= }} ==Problem description== No Power, 5v and ~0.02A current draw on the A1708 MacBook diagnosis and repair. thumb|Example image (Figure 1) -- No image yet. Help expand this page by uploading it! ==Symptoms== *Not turning on *Charger stuck at 5V with a current draw of 20 milliamps as measured by a USB-C meter ==Solution== Remove the shield over U2800 (Fig...")
Device
Affects part(s)
Needs equipment
Difficulty
Type
  • Not turning on
  • Charger stuck at 5V with a current draw of 20 milliamps as measured by a USB-C meter
Remove the shield over U2800 (Figure 1), clean and inspect all components around it, reflow if necessary.
