Resistors - Repair Basics | |
Type | Component |
Device(s) | Resistors |
Difficulty | ◉◌◌◌ Easy |
What is a Resistor?
Voltage divider
Uses:
- And much more
Resistor sensors
Pull-up / Pull-down
Pull-up and pull-down resistors are commonly used in digital electronics to ensure that a digital input signal is in a known state when it's not actively being driven by an external source. They are essential for preventing floating or undefined states
Current measurement
Fixed value resistors
SMD Fixed value resistors
THT Fixed value resistors
Variable resistors
Potentiometers
Thermistors
Varistors
Photoresistors
Testing a Resistor
Replacement Considerations
