Diodes - Repair Basics
Revision as of 14:27, 17 July 2024 by ASRepairs (talk | contribs)
Type Component
Device(s) Diodes
Difficulty ◉◌◌◌ Easy
Diode symbols commonly found in schematics (Figure 1)
What is a Diode?
One way path
The most basic function of a diode is to serve as a unidirectional pathway for the flow of electrical current.
Rectification
Voltage Regulation
Zener diodes, a specific type of diode, are used to regulate voltage. They maintain a constant voltage across their terminals despite changes on the supply voltage, making them suitable for reference voltage used in power supplies and protecting sensitive components from voltage spikes.
Protection
Photodetection
Some diode packages and types (Figure 2)
Diodes come in different physical cases that are either SMD or THT they can look identical but have different properties, outlined below is the different types of diodes.
Full bridge rectifier diode in multiple packages + diagram (Figure 3)
Regular/Rectifier Diodes
Schottky Diodes
Zener Diodes
Zener diodes are designed to maintain a constant voltage across their terminals when operated in the reverse-biased breakdown region. This means Zener diodes conduct backwards at (and only at) a specific *Zener* voltage.
They are used for voltage regulation and are often labeled with their nominal voltage value.
Light Emitting Diodes (LEDs)
Transient Voltage Suppression Diodes (TVS)
They operate by quickly diverting excess voltage away from the circuit they are safeguarding, preventing damage to components.
Varactor Diodes
Varactor diodes, also known as varicap diodes, are used in tuning and frequency modulation applications due to their ability to change capacitance with a varying reverse bias voltage. Rarely used in consumer electronics today.
Photo-diodes
Measuring a Diode (Figure 4)
Testing a Diode
Make sure the diode does not have any physical damage such as liquid damage/corrosion first! That's the quickest way of identifying a faulty diode.
  1. Identify the anode and cathode terminals of the diode. The cathode is typically marked with a band or line on the diode's body.
  2. Set your multimeter to the diode test mode (usually indicated by a diode symbol).
  3. Place the red probe on the anode and the black probe on the cathode.
  4. The multimeter should display a voltage drop reading (around 0.2 to 0.7 V for silicon diodes). If it shows "OL" or less than 0.2, the diode is likely faulty.
  5. Polarity is a concern. If the diode has a reading when the probes are flipped that means the diode is faulty
Measuring a full bridge rectifier diode package is the same as measuring 4 regular diodes!
Diodes usually either fail in a fully open or fully shorted state. Rarely, the diode is damaged in such way that the voltage drop across it is outside the rage.
Identifying a Zener diode's zener voltage
  1. Remove the diode from the circuit.
  2. Solder a 1 Kilo Ohm resistor in series with the Zener diode, connecting it to the anode terminal, for example.
  3. Using a Lab-Bench Power Supply, connect the positive terminal to the cathode of the diode and the negative terminal to the other end of the resistor.
  4. Place your multimeter in DC voltage mode and connect its probes across the diode.
  5. Gradually increase the power supply voltage until the reading on your multimeter no longer rises.
  6. The voltage at which the multimeter reading plateaus represents the Zener voltage for this diode.
Replacement Considerations
  1. Type: Ensure the replacement diode is of the same type and has similar electrical characteristics as the faulty diode.
  2. Forward Voltage: Match the forward voltage rating closely to the original diode. Using a diode with a significantly different forward voltage may affect circuit performance.
  3. Reverse Voltage (Zener): Pay attention to the reverse voltage rating. That's the most important parameter for Zener diodes.
  4. Power Rating: Match or exceed the power rating of the replacement diode with the original diode.
  5. Package Type: Choose a replacement diode with a compatible package type and size. Different packages have different mounting and pin configurations. If space is not a concern, you can use any size as it won't affect the circuit behavior.
  6. Reverse Recovery Time: In high-frequency applications, the reverse recovery time of the diode is crucial. Ensure the replacement diode has a similar or faster reverse recovery time.
