Capacitors - Repair Basics
Revision as of 14:27, 17 July 2024 by ASRepairs (talk | contribs)
Type Component
Device(s) Capacitors
Difficulty ◉◌◌◌ Easy
Capacitor symbols commonly found in schematics (Figure 1)
What is a Capacitor?
A Capacitor is a fundamental electrical component found in every single electronic device. Its primary function is to store and release electrical energy.
Capacitors store and release electrical energy in the form of an electric field. They consist of two conductive plates separated by an insulating material, often referred to as a dielectric. This means that there is almost infinite resistance between the plates.
You can think of a capacitor as a very tiny battery that is able to charge and discharge VERY quickly.
Capacitors are measured in "Farads (F)". Though farads are huge units, you'll typically find them in Nano (nF), Micro (uF), and Milli (mF).
Capacitors in schematics look like in Figure 1 and are usually denoted with the letter C followed by an identifier number. (E.g. C211)
Energy Storage
Camera flash Capacitor (Figure 2)
Smoothing capacitors on the input/output of a DC-DC converter circuit (Figure 3)
Voltage Smoothing
Low-pass and High-pass filters (Figure 4)
Timing circuits
Astable 555 timer circuit (Figure 5)
Some capacitor packages and types (Figure 6)
Capacitor types (Figure 7)
Fixed value Capacitors
Electrolytic Capacitors
Ceramic Capacitors
Film Capacitors
Tantalum Capacitors
Variable Capacitors
Testing a Capacitor
Before testing the capacitor, ensure it is discharged by shorting its terminals with a resistor (20-100 ohms) until you read the voltage on the capacitor to be zero.
If you've ruled out capacitor shorts but are still encountering abnormal or suboptimal circuit behavior, the next step is to evaluate the capacitors using an LCR meter outside the circuit as well.
Replacement Considerations
  1. Capacitance: Choose a replacement capacitor with the same capacitance value as the faulty one especially if it was used in timing circuits. If the capacitor was used for voltage smoothing, larger capacitances will work as well.
  2. Voltage rating: Pick a capacitor with a voltage rating that matches or exceeds the original one. In most cases, a higher voltage rating merely results in a larger physical size, as the voltage rating indicates the capacitor's voltage-handling capacity.
  3. Type: Try to stick to the same type as the original capacitor. However, depending on the application, you can use a different type if the size is not a concern.
  4. Physical size: Preferably, try to choose a replacement capacitor with the same dimensions as the faulty one. If this isn't available and size constraints are not an issue, you can opt for a larger or smaller capacitor as long as it matches the voltage rating, as this will function the exact same way.
