| Simovert VC 6SE7021-8EB21-Z No RS-485 communication repair | |
| Device | Simovert VC 6SE7021-8EB21-Z |
| Affects part(s) | ICs SN65HVD1176DR, SN74AHCT08Q |
Fixing an issue with this Siemens Simovert VC inverter where there is no communication on RS-485.
- No RS communication otherwise works fine
Make sure the port itself is not damaged. If it's okay, check the cable connecting the front panel to the CPU board. If that's also good then replace the 2 ICs marked on figure 1. In this case, replacing both fixed it.
