| MacBook Pro A1708 Kills USBC devices repair | |
| Type | Soldering, Micro-Soldering"Micro-Soldering" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property. |
#incomplete
- Kills USB-C devices
Make sure that 20 V is only present on C3101 OR C3201 (PP20V_USBC_XA_VBUS OR PP20V_USBC_XB_VBUS). If A is making 20 V on B, or vice versa, likely need to replace the MOSFETs Q3100 and/or Q3200, since they're letting 20 V through (backwards!) when they're not supposed to.
