MacBook Pro A1708 Not turning on, pulling 0.35A at 20V repair
Revision as of 09:27, 27 October 2023 by ASRepairs (talk | contribs)
Device MacBook Pro A1708
Affects part(s) Motherboard
Type Soldering, Micro-Soldering"Micro-Soldering" is not in the list (Soldering, Teardown, Part replacement, Cleaning, Software, BGA, General) of allowed values for the "Repair Guide type" property.
#incomplete
  • Not turning on
  • Pulling 350 milliamps at 20V as measured by a USB-C meter
PP5V_S5 missing — check and reflow or replace U7650 (TPS51980) with proper pads cleaning (especially on the PPBUS_G3H_P3V3S5 input of U7650). Possible problem: Apple refurbished board; solder over corrosion causing bad joint. Example of replacing a corroded TPS51980
Dead CPU or bad BIOS can also present like this.
