Repair guides are stubs by default! If you believe the guide you wrote has little to no improvements left then you can remove the stub tag either by clicking on it in visual editor and then delete or by removing the {{Stub}} in source editor.
- Affected parts: the parts which the guide is intending to repair/fix. E.g. Motherboard, Display assembly, Speaker, Touch sensor.
- Equipment needed: input everything you used to repair the problem from tools used to open the device to tools used to replace the broken/faulty parts.
- Type: choose the type of repair guide
- Difficulty:
- Easy: only for part replacement where the parts can be easily obtained and there is little to no risk of breaking the device while trying to replace it
- Medium: for part replacement if the parts/tools can't be easily obtained and there is mild risk of breaking the device while opening/replacing
- Hard: anything that includes soldering
- Specialist: BGA reworking
